OpenBuilds CAM SVG import error.
Discussion in 'CAM' started by dwelch, Apr 13, 2024.
  1. dwelch
    dwelch New
    New thread....straight to the point.
    I had issues importing SVG files. The dimensions would be wrong. For example
    Code:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <svg
       width="612pt"
       height="792pt"
       viewBox="0 0 612 792"
       version="1.1"
       id="svg1"
       xmlns="http://www.w3.org/2000/svg"
       xmlns:svg="http://www.w3.org/2000/svg">
      <defs
         id="defs1" />
      <g
         id="surface1">
        <path
           style="fill:none;stroke-width:10;stroke-linecap:butt;stroke-linejoin:miter;stroke:rgb(0%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;"
           d="M 0 0 L 720 0 L 720 720 L 0 720 Z M 0 0 "
           transform="matrix(0.1,0,0,-0.1,0,792)"
           id="path1" />
      </g>
    </svg>
    It detects the units from the height and width. Through discussion it defaults to 96dpi if it cant determine who created it. If you save out of inkscape with plain svg for example. If you save out as inkscape svg then openbuilds cam is happy, well okay I am happy as my 72 points becomes one inch. Instead of some other number.
    Code:
       inkscape:version="1.3.2 (1:1.3.2+202311252150+091e20ef0f)"
       xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
       xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
    Dont remember which but two of these three lines up front, at this time then take you down the path of success and the size of the path/box is 1 inch or 25.4 mm.
    The bug I will call it is you instead get 25.4*0.9375 = 23.8125 mm instead.
    If you change those to say mm instead of pt the tool recogizes the unts as mm now but still has this 0.9375 error it is converting millimeters to millimeters with a scaling of 0.9375.
    Here is the issue. Not too far back sounds like inkscape changed from 90 to 96DPI and openbuilds cam did as well, but.....There appear to be a number of places that have the scaling.
    90 / 25.4 = 3.543307087
    96 / 25.4 = 3.779527559
    and
    90 / 96 = 0.9375
    There is that percent error that affects these simple/plain svg files. (Inkscape or other generated).
    You can grep for 3.543307 and find many hits. or grep for 'pt' or 'mm' and so on and run into a handful of places where code like this exists:
    lw.svg-parser.js
    Code:
                    if (stringValue.indexOf('mm') !== -1) {
                        return floatValue * 3.5433070869;
                    if (stringValue.indexOf('cm') !== -1) {
                        return floatValue * 35.433070869;
                    if (stringValue.indexOf('in') !== -1) {
                        return floatValue * 90.0;
                    if (stringValue.indexOf('pt') !== -1) {
                        return floatValue * 1.25;
                    if (stringValue.indexOf('pc') !== -1) {
                        return floatValue * 15.0;
    If you go in and change the 1.25 to 1.3333333 for points.
    Code:
    Now when you import that file you get the correct 25.4 mm on a side as desired.
    You can see the 90 in there for inches should be 96 and so on.
    I did not find out when the other hits on this type of table are used, I just figured out the one that was affecting what I was trying to do.
  2. dwelch
    dwelch New
    Security Error: Content at file:///home/dwelch/Desktop/OpenBuilds-CAM/index.html may not load data from file:///home/dwelch/Desktop/OpenBuilds-CAM/workers/toolpath/worker/toolpathworker.js.
    How does one resolve this (gcode generation when running a clone locally)?
    Run it off a local web server (http:// not file://)
    http-server or apache / nginx / anything thats quick to spin up
    I think you nailed it! Thanks for the legwork, that was not quite obvious but if you take the timeline into account it makes sense. The lw parser does predate Inkscape's catch-up.
    Moved to Github svg parser 90/96dpi · Issue #98 · OpenBuilds/OpenBuilds-CAM
  5. dwelch
    dwelch New
    lighttpd worked great (used it before so tried it first). thanks!
    So seems like it's less an Inkscape changing from 90 to 96dpi issue, but rather CSS changed scaling of Pt to 1.333'px from 1.25px so this bug should only affect drawings done in Pt (and only in newer versions of design applications adopting 1.333'px = 1pt) Is that your observation as well?
    Does not seem to affect other units from what I can tell?
    Weird that the parser written in 2016 got that wrong :) but easy fix
  7. dwelch
    dwelch New
    mm were broken as well would get that same 90/96 0.9375 ratio 100mm would import as 93.75mm The whole set is based on 90 (inches is 90 instead of 96 for the value, etc).
  8. dwelch
    dwelch New
    <svg
    width="100pt"
    height="100pt"
    viewBox="0 0 100 100"
    version="1.1"
    id="svg1"
    xmlns="SVG namespace"
    xmlns:svg="SVG namespace">
    <defs
    id="defs1" />
    <g
    id="surface1">
    <path
    style="fill:none;stroke-width:1;stroke-linecap:butt;stroke-linejoin:miter;stroke:rgb(0%,0%,0%);stroke-opacity:1;stroke-miterlimit:10;"
    d="M 0 0 L 100 0 L 100 100 L 0 100 Z"
    id="path1" />
    </g>
    </svg>
    point
    100/72 = 1.38888
    1.38888 * 25.4 = 35.27777
    return floatValue * 1.333333333
    G1 F1000 X35.2778 Y35.2778 Z-1.0000 S1000
    G1 F1000 X35.2778 Y0.0000 Z-1.0000 S1000
    <svg
    width="100mm"
    height="100mm"
    version="1.1"
    id="svg1"
    <defs
    id="defs1" />
    <g
    id="surface1">
    <path
    id="path1" />
    </g>
    </svg>
    G1 F1000 X93.7500 Y93.7500 Z-1.0000 S1000
    G1 F1000 X93.7500 Y0.0000 Z-1.0000 S1000
    90/25.4 = 3.543307087
    96/25.4 = 3.779527559
    return floatValue * 3.779527559;
    G1 F1000 X100.0000 Y100.0000 Z-1.0000 S1000
    G1 F1000 X100.0000 Y0.0000 Z-1.0000 S1000
    <svg
    width="1in"
    height="1in"
    viewBox="0 0 1 1"
    version="1.1"
    id="svg1"
    <defs
    id="defs1" />
    <g
    id="surface1">
    <path
    d="M 0 0 L 1 0 L 1 1 L 0 1 Z"
    id="path1" />
    </g>
    </svg>
    G1 F1000 X23.8125 Y23.8125 Z-1.0000 S1000
    G1 F1000 X23.8125 Y0.0000 Z-1.0000 S1000
    return floatValue * 96.0;
    G1 F1000 X25.4000 Y25.4000 Z-1.0000 S1000
    G1 F1000 X25.4000 Y0.0000 Z-1.0000 S1000
    All of them not just 'pt'
  9. Peter Van Der Walt
    Thats a shame as then the change from 1.25 to 1.333 for Pt isn't the issue..something else is still wrong (90 vs 96dpi).
    Ok lets leave the Github issue open, will debug when I can, couple urgent projects I am tied up on first
  10. dwelch
    dwelch New
    does fix it for 'pt' it does not fix it for mm, in, cm, etc as the 1.25 is specific to pt. the code separates all of them pt, mm, in, cm... Did I misrepresent that pt did not work?
  11. Peter Van Der Walt
    No you didn't misrepresent anything, I just haven't been able to dig in so was just doing some sideline research. Pt is the outlier though (96 vs 72dpi) others have a 90vs96dpi difference, so little unsure where the root of this bug lies but sure I will find it when I get time to properly dig in. Just wanted to be sure I understand your tests.
    Particularly as non-plain SVGs don't scale incorrectly.
    Taking a look at the SVG in your first post, first XML, i still don't see a way for us to determine the DPI it was exported as.
    Its exported as 90dpi (which we can calculate outside of the XML because we know what the intended size is supposed to be) but with just the XML, how should the parser know if its 90 or 96dpi. I don't really blame the code for going with 96dpi (far more standard than 90) if theres nothing to determine it from.
    Even ChatGPT can't figure it out (even further out) as the XML does not tell us what DPI its been exported as
    Easy if you know the values you used (either dimensions or dpi), impossible to guess if there isn't any metadata in the file.
    pt is not a physical unit its an onscreen unit. To convert to realworld dimensions needed for a CAM, you need to know how many pts is in a mm (or pt > px > dpi)
  12. dwelch
    dwelch New
    I get that and that is a fair argument, No I have not remotely read the whole svg spec, only wee tiny fractions through searches, but even where talks about the 1.25 and such is in reference to CSS not svg. One forum/question hit somewhere the person stated the 96dpi default for svg. Cant find that (yet).
    So one could argue as a target you get to chose, my argument to that is you made changes to keep in sync with inkscape, so this is just a continuation of that. Clearly open builds cam detects the units from
    width="612pt"
    height="792pt"
    If a plain file (And perhaps even if it has all the inkscape fields not, didnt test that yet). and you change those and it changes the scaling based on the if then else tree in that code.
    So my argument is there were changes to be on par with inkscape so continue to make changes to be on par with inkscape and change the other places. I assume further that the if inkscape if illustrator if... is to keep on par with all of those. I guess a counter argument is that since it is not tagged as being from one of these specific tools (or stripped for various reasons before publication) then does it have to be inkscape like, response to that is most of your if-then-elses result in 96 with a default of 96. Hmm, I guess you could have 90 as the default if it falls through then the other tables dont have to change? I can test that...
    I am struggling to understand any defaults related to svg specifically. Cant tell if there are or not. At this point despite the CSS comments in the svg spec, I dont even know if browser to browser, operating system to operating system it matters. As DPI with respect to pixels on wikipedia indicates that windows is one way and mac is/was another. (72/96). Not to mention the mixing of terms bouncing around pixels and points and dots. PostScript which is my origin is 72, but once that gets converted straight over to svg then it is in the svg domain, and no longer postscript.
    Anyway, I can at least fix and run my own copy now if there is a desire not to change this. I will try changing the fall through default to 90 which should make the other scaling factors then work in these other or older files.
  13. dwelch
    dwelch New
    Okay and this makes sense...
    just doing this
    } else if (editor == "illustrator") {
    resol = 72
    } else if (editor == "Opentype.js") {
    resol = 57
    } else {
    resol = 90;
    Instead of resol = 96;
    File: hello.svg was created in unknown version NaN. Setting import resolution to 90dpi
    The 1.25 is now correct and
    G1 F300 X25.4000 Y25.4000 Z-2.0000 S1000
    G1 F300 X0.0000 Y25.4000 Z-2.0000 S1000
    And get the 25.4 mm I expected.
    (no need to test the other units as we can see the math on all of those is based on 90).
    That feels cleaner.
  14. Peter Van Der Walt
    Which works for your files, because they were created as 90dpi
    But mine is created as 96dpi, and then its wrong if I change the last "else" and remove my IDs so it falls to the bottom.
    No, the fallback will have to be 96dpi (industry standard). We need something to catch your 90s higher up before we get to the fallback... Some way to uniquely ID that these files are made as 90dpi
    I feel your pain. SVGs was never meant as a CAD format. DXF was. But the availability of artwork in SVG format so freely - note art not CAD - for art size doesn't matter - means we still need it around
    What tool do you use for conversion? Perhaps its setup for 90dpi export?
    From your deleted thread?
    Curious, whats the workflow? Print driver to PS to PDF to SVG to CAM?
    #14 Peter Van Der Walt, Apr 15, 2024
