Openbuilds CAM - Switch Laser off between cuts
Discussion in 'CAM' started by Ebasson84, Mar 22, 2023.
  1. Ebasson84
    Ebasson84 New
    HI there!
    Okay so I have an OX with a XPro V3 controller and then a laser (bought off Aliexpress).
    From beginning to end I have no real issue, other than the laser being on as it moves to the different cuts which I have specified. So it creates marks on the board I am busy cutting.
    How do I remedy this? Other than that everything is working perfectly.
  2. Giarc
    Have you Changed your grbl settings to laser mode? $32 settings.
  3. Ebasson84
    Ebasson84 New
    Thanks, problem solved. Much appreciated!
