Openbuilds Fusion 360 Post Processor Options
Discussion in 'CAM' started by Misterg, Feb 12, 2023.
  1. Misterg
    Misterg Veteran
    Hi folks,
    I'm plucking up courage to try the Openbuilds GRBL post processor for Fusion 360 at GitHub - OpenBuilds/OpenBuilds-Fusion360-Postprocessor: Post Processor for Fusion 360 for use with OpenBuilds Machines running Grbl 1.1
    (In fairness, I haven't had any particular problem using the built-in GRBL post processor, once I'd figured out G28.1, but I'm using the personal use version and am interested in regaining my rapid feeds.)
    Could someone explain the 'High feedrate mapping' options to me?
    (They appear as part of the 'Built in' block)
    I've looked through what documentation I can find on github, but am none the wiser. If there's some documentation elsewhere, then feel free to point me at it and I'll have a read.
    Thanks.
    You can ignore those builtin setttings, just leave the defaults and the post will work perfectly.
    (to be technical about it, that particular setting is ignored by the code anyway)
    #2 David the swarfer, Feb 13, 2023
    Misterg likes this.
  3. Misterg
    Misterg Veteran
    Ahh! That'll be why I couldn't find any difference between in the output for different options! :D
    Thanks.
