OpenBuilds OX CNC Machine
  1. GrayUK
    Thanks Frederic.
    I'll keep it in mind.
    Gray
  2. Chris Laidlaw
    Chris Laidlaw Well-Known
    Wow! I can't believe you got everything together and working in less than 3 weeks! Btw, nice looking gantry plates there ;)
  3. Frederic Goddeeris
    They
    do look good, don't they! :p
    Thanks again for making them for me and the excellent "customer service". Next time I will post pictures with the plates in focus :D
    Frederic
    #1143 Frederic Goddeeris, Aug 17, 2014
  4. dddman
    dddman Journeyman
    To everyone who have completed their OX, what did you cut with it and at what feedrates (XY and Z)?
    Chris Laidlaw and Robert Hummel like this.
  5. BinaryConstruct
    A while back someone asked how I was doing my max Z endstop, so I figured I would post it. Note: The camera lens makes it looks tilted, but everything is straight in reality.
    #1145 BinaryConstruct, Aug 18, 2014
  6. Frederic Goddeeris
    Hi BC,
    I have read that lots of noise can be picked up by the wires between switches and controller causing spurious alarms. http://wot.lv/combating-endstop-noise-on-a-reprap.html
    What controller do you use (grbl ?) and did you add some additional filters to combat any noise?
    Thanks,
    Frederic
  7. Frederic Goddeeris
    For the Z-axis, I glued my switches to the gantry plates. I used CA glue but the bond seems very brittle, I will need to try something else...
    Strooom likes this.
  8. Travis
    Travis New
  9. dddman
    dddman Journeyman
    I tried to cut 1/2" acrylic yesterday and I noticed some twisting in my X 20x60s when the spindle forces down on the material... is there any known way to reinforce the X beam? I also noticed that in SketchUcam, the multipass depth can't be under 1mm, is anyone aware of this problem? How can I fix it?
  10. Rick 2.0
    Bonding the two plys together will double the strength and give you 4 times the stiffness (about the weak axis that is). You might check to see how well J-B Weld works on anodized.
  11. oni305
    oni305 Well-Known
    from this useful link http://www.shapeoko.com/wiki/index.php/Materials
    Code:
     Acrylic
    Notes from IC for cutting his dust shoe:
        Bit: double flute 3.175mm (1/8") end mill
        Feed: 400mm/min
        Speed: 20,000 RPM
        Cut Depth: 2mm (0.08")
        Stepover: n/a (through cut)
        Plunge Rate: 75mm/min.
    O-flute bits are recommended.[27]
    Makita RT0701 16in/min feed, 0.08" step down[28] at speed 2 (~12,280 r.p.m.)[29]
    10mm cast Acrylic using 6mm Single Flute bit 2mm depth 400mm/min Feed speed.[30]
    Fabrication Notes
    Extruded acrylic tends to "store" energy and may randomly crack if one presses in a part as a friction fit. This happened when I.C. tried pressing in the magnets on his DWP611 shoe and broke a couple.[31]
    The edges may be polished after cutting by rapidly passing an open flame over them and quickly allowing the material to melt and cool.
    You may wish to consider misting the material w/ water[32] and/or dishwashing liquid[33] as a coolant or applied to the bit as a lubricant[34]
    Evan F and Chris Laidlaw like this.
  12. dddman
    dddman Journeyman
    Well... I was WAY too fast... I think I went 1000mm/min and 700mm/min... with 1/4" edmill... will try again tonight :p
    #1152 dddman, Aug 19, 2014
  13. John Ellis
    The parts lists shows 7 feet of GT3 Timing Belt. Perhaps my math is off, but isn't there two 1500mm Y-axis steppers and one 500mm X-axis stepper for a total of 11.5ft plus slack (say 6" per run) for a minimum order of 13 feet?
  14. Rich C
    Rich C New
    John, I see the BOM showing 1ea 20x80 v-slot for the y axis (sides) cut in half (750mm for each side). With this, you only need about 7 feet for both the x and y axis
    If, however, you decide to build a larger OX with a 1500mm y-axis for example, then you would need an additional 5 feet (approx.) of GT3
  15. John Ellis
    Ah, so my math was fine, but my inputs (assumptions) were wrong :) Thanks for the quick correction.
  16. Rich C
    Rich C New
    Speaking of a larger OX, I decided to build a 750x1500 OX. I have finished the table, got my computer, monitor and keyboard/mouse setup, started putting the frame together, and test fitted the gantry. It's coming along but I am waiting on some screws to finish the x/z plates, then I'll move on to the electronics. I was going to post the build, but I got so engulfed, I already had the table built before I got off any pics. Maybe I will try to start a build thread tomorrow...
    BTW, Chris, the aluminum parts are all phenomenal. Thanks
  17. dddman
    dddman Journeyman
    I uninstalled SketchUp annd reinstalled it, all is OK now. If you have to use the comma for the measurements, and want to use the point, you have to change your regional settings in Windows.
  18. GrayUK
    Come on Justin, you can't keep fighting it! I'm way older than you, and even I've gone metric! :banghead:
    I admit, I can't really visualise 300mm etc, as I can 2 foot or eight inches, but when it comes to calculations, it's a breeze.
    Kids have got it so easy over here with going metric! :p
    I think I've had this conversation before.
    So I'll shut up! :zipit:
    Gray
    Cornerspace likes this.
  19. Rick 2.0
    If you're thinking 300mm is close to either of those two choices, I'd have to agree. o_O
    Seriously, if you can visualize 4" you can visualize 100mm as that is a rough translation. Everything beyond that is just a multiple. 300mm ~ 12", 2' ~ 600mm, 8" ~ 200mm, etc.
  20. dddman
    dddman Journeyman
    To convert decimals it's a bit harder... 1/4" is 6.35mm 1/8" is 3.175mm etc... but metric decimals are a lot easier!
  21. offtrolley
    If I remember correctly, 25.4mm is the key to conversion
    So 12 inches = 12 x 25.4 = 304.8mm
    1/4 inch (.25) = .25 x 25.4 = 6.35mm
  22. dddman
    dddman Journeyman
    You are right
  23. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    My father told me about Inches :)
    Tweakie.
    GrayUK and Robert Hummel like this.
  24. GrayUK
    Oh that was hurtful! :cry:
    But really good reply. :D
    Gray
  25. Jeferson SImoes
    Anyone measured the backlash with gt2 3mm belt?
  26. Evan Price
    Hey all, I was wondering if there would be too significant of deflection if I used the OX design and extended the X axis using the same 60x20 v slot to allow for a 4x4 foot cutting area. Thoughts?
  27. Tweakie
    Moderator
    Working area (size) and the type of machine design depends to a large extent on the loading you are intending to apply to the tool being used.
    Just for example; "V-Carving" imposes significant tool loading whereas "laser engraving" imposes none.
    What is your intended usage for your machine ??
    Tweakie.
  28. Jonathan Trinity
    Hello Friends.
    I was looking to build a cnc but all i saw was wood builds with very little reliability. And then i found this forum and i have to say that is amazing. Congratulations to all you guys that make it possible.
    I have two questions.
    1 - I found in my country (Portugal) a company that can cut the ox plates but with 5mm aluminium and not 6, is this a problem?
    2 - Is it possible that someone can tell me the measurement of the ox gantry plates? (width, heigth) I will print the plates in pdf with measures on paper and take to the shop to compare the final result with the prints.
    Thanks,
  29. Jonathan Trinity
    yes i saw it but i'm new to cnc and here in Portugal people tend to not follow very well indications provided. What i want to know is if i give the dxf file to a company is it possible that they cut the all thing wrong?
    And they only cut 5mm aluminium. I saw that everyone is doing with 6mm.
  30. Evan Price
    Tweakie,
    I am definitely planning more on the V-cutting and 3d routing type of use. If this is the case will I need to use 8020 rather than the 6020 vslot? I am not too familiar with deflection calculations, I am more of an electronics guy at heart.
