Openbuilds post processor for Vectric
Discussion in 'CAM' started by Alex Chambers, Dec 12, 2021.
  1. Alex Chambers
    I'm getting reports that Vectric are saying that the OB post processor for Vectric software (specifically Vcarve) V11 is not supported and that people should us a post processor provided by Vectric. I don't have V11 Vectric software, so I can't investigate this myself, but the person I was trying to help says that the Vectric post processor turns the spindle off during rapid moves and then on again for the next cut move.
    Any thoughts on this people? (@David the swarfer, @sharmstr)
  2. sharmstr
    They changed the way the post works in V11. So if you upgrade and you were using the OB post that OB has posted in the resources before, you need to switch to the built in Vectric post. (OpenBuilds GRBL (mm) (*.GCODE) and OpenBuilds GRBL (in) (*.GCODE). It works great. It was a bit confusing to setup after the upgrade because it tried to use the old one and the names are the same. So, they need to
    go ino the machine config management screen, delete everything in Associated Post-Processors
    Click on + to add new post
    Click on the download from cloud button on the bottom right
    Click yes to get updated posts
    Scroll down the list and choose which Openbuilds post they want to add (mm or in)
    Done.
    If they need help, they can hit me up.
    @Peter Van Der Walt : Maybe update the docs since the screens are different now? I'm sure you have all the time in the world to do it :)
    Alex Chambers likes this.
  3. sharmstr
  4. Alex Chambers
    Thanks for that - I'll pass that on
  5. Alex Chambers
    No, haven't looked at the g-code file yet - was my bedtime when this came up last night. I suspect the issue was the need to delete the OB post to avoid the name clash.
  6. David the swarfer
    sounds like they have laser mode set (GRBL $32 parameter)
    Downloading V11 now - will update docs this week
    Definately has Laser Mode enabled... G0=off, G1/2/3=on (as it should for lasers, not for spindles)
  8. Alex Chambers
    Thanks @David the swarfer, @Peter Van Der Walt -have passed that on.
    As David and Peter predicted, the OP has just confirmed that laser mode was the issue, so thanks to you both on his behalf (have suggested he joins the forum)
    #8 Alex Chambers, Dec 13, 2021
  9. TopDawg1750
    I am using Vetric. What is the proper post Processor and what settings must be set for plasma?
  11. B-rad Gerbil
    FYI, in Aspire 12.0, you must choose "GRBL G-CODE mm" as if you choose "inch" mode, you will get a tiny version of your design. :)
  12. David the swarfer
    that means the inch post is not putting a G20 code in the header, this tells the controller to regard incoming numbers as inches.
    G21 tells it to expect millimeters.
    Every Gcode file should have the expected code at the top so you don't get surprises and don't have to remember to put the controller in the right mode before starting.
  13. Peter Van Der Walt
