OpenBuilds XYZ Touch Probe Plus wizard
Discussion in 'CNC Mills/Routers' started by JRMN, Oct 28, 2022.
  1. JRMN
    JRMN New
    Two questions...
    Has anyone ever wired two touch probes at the same time? I have the OB XYZ Touch Probe Plus and one of these.
    Will the OB XYZ Touch Probe Plus wizard work with the type of touch probe above? If not, is there a macro that will?
    At the same time: only both are Normally Open (XYZ Probe Plus is)
    You can give it a go as a Custom probe with Z offset = 0, and XY offset = how ever much it moves between contact and trigger
  3. JRMN
    JRMN New
    Thanks, Peter. I will try that some time this weekend.
