ox cnc plate hole measurements
Discussion in 'CNC Mills/Routers' started by phillip hawks, Feb 19, 2022.
  1. phillip hawks
    hello maybe ive posted this in the right place im needing help ive cut my plates out for the ox cnc version 4 can anyone have the measurements for were to drill the holes i no this is asking alot so if anybody can help i would be truly thankfull phillip
    Not sure what you mean by version 4 but the best reference I can offer for hole locations would be OpenBuilds OX CNC Machine. The drawing provided can be printed at actual size and used as a template.
    Would make a small change to the numbers stated though. Revise 79.8mm and 99.8mm to 80.0mm and 100.0mm respectively. The numbers stated have shown to be a bit on the small size and depending on the extrusion run may make the wheel fit up a bit tight.
  3. phillip hawks
    hello rick thank you this will work im trying too save some money builded them myself im ordering my hardware today cant wait to get started thanks again phillip in galax va
