Plasma Cutter
Discussion in 'OpenBuilds Forum Help' started by David Miner, May 8, 2023.
  1. David Miner
    So I installed the black box and things are looking up. I ran a program to check that all is working and it doesn't shut down when I turn on the plasma and it doesn't YAHOOOOOO.
    Been working on this project for three plus years now and this is the 3rd board I'm trying.
    Here's my question.
    I believe that I connect the two wires to my plasma machine were the switch is for running the plasma at the RELAY plug. Is that correct? I connected my DC meter to the relay points and I don't get any contact showing. I also tried then Ohm and nothing. could this also be not in the program to tell it to turn on or off and it is not raising the Z axes between cuts.
