Probe having issues. Alarm 4
Discussion in 'Interfaces' started by sackindustries, Aug 30, 2023.
  1. sackindustries
    Hello! I’m having an issue in interface where the probe invert is always on. I change it and it stays…
    also I cannot control z motor in CONTROL, I can control Z in the interface.
    extremely frustrated with this right now. Spent the whole day on it trying to mill some extrusions, but can’t even get it to prove right.
    Attached is the video.
  2. sackindustries
    I didn’t figure it out, but it all of a sudden works again. I didn’t even do anything to it. Sounds like a bug.
  3. David the swarfer
    your rude signs do not inspire us to help you, not funny, not cute, not helpful
    use Interface OR use CONTROL, not both at the same time, not clear from the little you said as to exactly what you are trying to do with the 2 systems.
    do all your setup (like changing probe invert) with CONTROL, then Interface will obey the settings that are stored in the controller..
  4. sackindustries
    I'm only using one or the either. Not both.
    What was frustrating was that it let me invert the probe in interface, but didnt let me change it back. Spent 4 hours trying to figure it out. I even tried flipping it in CONTROL, but it didn't work which made it even more annoyingly frustrating. I'm sure you all have these moments, especially with a finished product. Anyway, there's a bug there that someone is going to run into eventually as well.
