Probe interface problem
Discussion in 'CNC Mills/Routers' started by Romain Wood, Jan 10, 2023.
  1. Romain Wood
    good morning
    since update 1.57 the probe no longer works.
    I work with the black box 4 and the interface
    the bet went well but since then the probe via the interface no longer works.
    here is the error I have on the interface screen:
    GRBL error
    Error n2
    numeric value
    Not valid
    I tried to make the probe with the black box directly and it works
    Everything is up to date
    can you give me solutions to my problem?
    Thank you
    #1 Romain Wood, Jan 10, 2023
    OpenBuilds CONTROL (Latest version) > Wizards and Tools > Prepare USB drive and make sure to select the correct controller
  3. Romain Wood
    ok but interface or Blackbox X4?
    thank for your answer
  5. Romain Wood
    Ok I just did the manipulation and it does not solve the problem
    here is what i do
    I will look for the file in the PROBE folder
    I select ¨ROBEXYZ PRB and nothing happens
    I cancel and strangely I can launch the sequence like a machining program
    but as soon as he touches the probe he gives me the error
    firmware interface black box 1.57
    openbuilds controle 1.0.344
  6. Romain Wood
    I made a mistake in my way of launching the probe sequence I am really sorry because in fact it worked very well from the beginning
    all my excuses
  8. Romain Wood
    thank you for your answers
