Probe tool bit size mm/inches
Discussion in 'CNC Mills/Routers' started by Bruce Hadden, Jun 14, 2022.
  1. Bruce Hadden
    I am a newbie to CNC and all parts involved and still taking baby steps. I am setting up my probe and is working fine. For some reason I am unable to switch the tool bit diameter from the default mm to inches. It look like it should be a drop down box but it's not.
    Probe only supports mm at this time
    Use the AUTO mode to avoid entering values completely
  3. Bruce Hadden
    OK I give up. How do I find the Auto mode
    Click the Tab along the top:
  5. Bruce Hadden
    I get it now, I have a probe from Mill Right. It does not have the hole for bit diameter.
    Thanks for the help!!
    I can transpose to mm for now
    Thank Again
    Correct, for optimum feature set and usability - CONTROL is primarilly meant for use with our products
  7. Bruce Hadden
    Is there any way to slow the Jog rate in the probe action. It's movment is almost violent and moves the probe itself and has knocked my probe wire loose!
