Probing not working right on BB x32 and OB controller
Discussion in 'Controller Boards' started by goldentuna, Feb 17, 2023.
  1. goldentuna
    I'm using the OB xyz probe (though it doesn't work on others either) same for z or xyz
    Position xyz probe > go to probe wizard > select Probe for Z > confirm position > click probe button ... nothing happens.
    It shows a pause button and stop button at top. If I click on the pause > then resume > the probe routine begins.
    It probes down to plate > green light comes on > stops (does not move up)
    I then click on the stop button and when I use the keys to move the Z up I get the error:
    error: 1 - G-code words consist of a letter and a value. Letter was not found. [ $J=G91 G21 Z1000 F375 ]
    I click on cancel > then get the dialogue that the probe has finished.
    It does give me the correct Z offset ... but, seems something is not right.
  2. sharmstr
  3. goldentuna
    No, I'll try that
  4. goldentuna
    That did work - thanks!
