Problem homing Z with grbl- Please help
Discussion in 'Controller Boards' started by mendelevium, Apr 18, 2020.
  1. mendelevium
    Hi All,
    I am a CNC machinist by profession and own a CNC machine shop. I build 3D printers as well. Anyway got the idea to build a laser and constructed a metal frame powered with Nema 17, arduino Uno clone by static boards and a V3 CNC shield.
    I have 2 limit switches wired in series to act as Normally Closed in X and Y axis and a Z axis limit switch .
    I have Z limit switch NC in Z+
    Here is my grbl settings below...
    My problem is that Z will not home.
    At first it would not even move then I undefined in Config.H the VARIABLE_SPINDLE
    then Z started to move.
    At first I had the machine fitted with A4988 Stepper drivers.
    My machine used to make the homing action in Z as if it has reached the microswitch. Just lift up and down a few mm, then proceed to home X and Y. This action does not even touch the Z homing switch but X nad Y homes seamlessly.
    I then fitted the DRV8825 with the three jumpers fitted.
    I made the settings relevant to the stepper in terms of steps per mm etc etc.
    When disabling the homing everything works just fine.
    When enabling homing, when I home, the Z would creep up slowly making a strange noise and if I touch the Z limit switch nothing happens.
    Through the verbose output< i know the switches are working.
    I also tried hooking a small switch on the CNC shield to test if the issue was interference but it behaves exactly the same....
    I am stuck guys so any assistance appreciated as I have been in this hole for a week.
    when disabled, i can jog and the limit switches work seamlessly.
    I have come across someone who suggested using the D12 pins but I have tried to check via the verbose output but there is no response.
    I am looking for some help. Thanks in advance...
    Tonio
    **** Connected to COM11 @ 115200 baud ****
    Grbl 1.1h ['$' for help]
    $0 = 10 (Step pulse time, microseconds)
    $1 = 25 (Step idle delay, milliseconds)
    $2 = 0 (Step pulse invert, mask)
    $3 = 0 (Step direction invert, mask)
    $4 = 0 (Invert step enable pin, boolean)
    $5 = 1 (Invert limit pins, boolean)
    $6 = 0 (Invert probe pin, boolean)
    $10 = 1 (Status report options, mask)
    $11 = 0.010 (Junction deviation, millimeters)
    $12 = 0.002 (Arc tolerance, millimeters)
    $13 = 0 (Report in inches, boolean)
    $20 = 0 (Soft limits enable, boolean)
    $21 = 1 (Hard limits enable, boolean)
    $22 = 1 (Homing cycle enable, boolean)
    $23 = 7 (Homing direction invert, mask)
    $24 = 250.000 (Homing locate feed rate, mm/min)
    $25 = 10.000 (Homing search seek rate, mm/min)
    $26 = 250 (Homing switch debounce delay, milliseconds)
    $27 = 1.000 (Homing switch pull-off distance, millimeters)
    $30 = 1000 (Maximum spindle speed, RPM)
    $31 = 0 (Minimum spindle speed, RPM)
    $32 = 0 (Laser-mode enable, boolean)
    $100 = 161.250 (X-axis travel resolution, step/mm)
    $101 = 161.250 (Y-axis travel resolution, step/mm)
    $102 = 833.000 (Z-axis travel resolution, step/mm)
    $110 = 3000.000 (X-axis maximum rate, mm/min)
    $111 = 3000.000 (Y-axis maximum rate, mm/min)
    $112 = 1000.000 (Z-axis maximum rate, mm/min)
    $120 = 100.000 (X-axis acceleration, mm/sec^2)
    $121 = 100.000 (Y-axis acceleration, mm/sec^2)
    $122 = 100.000 (Z-axis acceleration, mm/sec^2)
    $130 = 630.000 (X-axis maximum travel, millimeters)
    $131 = 200.000 (Y-axis maximum travel, millimeters)
    $132 = 150.000 (Z-axis maximum travel, millimeters)
    ok
    >>> $G
    [GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0]
  2. Giarc
    Your issue may be the V3 cnc shield does not have the right pinouts to run stock GRBL 1.1 -- particularly for the z axis. It has to be a V3.1 or higher board. See the pinouts here gnea/grbl. Unless you actually remapped it. If so than ignore me. :) D12 is the z limit switch in Grbl 0.9 or higher.
