Problem When Run Job in Z axis (Goes Down)
Discussion in 'CNC Mills/Routers' started by yanai navon, Mar 5, 2020.
  1. yanai navon
    Hi, I Have A problem with my G-Code from fusion 360 using GRBL open Builds Processer.
    I Set my zero location set Run Job (in open builds Controller) the machine goes Straight down on the Z-axis into the stock material and then goes up to the correct location and start the job.
    Thanks for the help.
