problem with steperronline motors connection
Discussion in 'OpenBuilds Bug Report' started by demaret eric, Jun 13, 2023.
  1. demaret eric
  2. Alex Chambers
    And don't forget to load a machine profile: CONTROL > Grbl Settings tab > Select machine from the list > Save and reset when prompted
  4. demaret eric
    thanks guy, i did all of that but because i can t test, because i v got no equiment.
    Its a homemade one so , i did put the things like belt for z and the other ones ans save.
  5. Alex Chambers
    The guide I linked you to tells you how to identify motor wiring pairs without a multimeter.
    Please start off with one of our profiles, at least the CUSTOM option if nothing else - to make sure key parameters are set correctly.
  7. demaret eric
    Ok i found the problem, i had to choose other machine which didn t appeared before.
    Thanks guy
  8. demaret eric
    Custom i mean
