I have with the movement of y2 axis it move very good but some times stop. I checked evry things stepper motor work fine and the axis screw installed properly. Also the wheels are good. Also I tried to increase the torque for the axis also same.
When it stops, does it stop temporarily (acceleration or max rate set too high, or mechanical slippage/binding, or intermittent loose connection in motor wiring) or does the Fault Indicator LED light up for that axis (motor wiring, current set too high, or faulty PSU) - fault LED stays lit until power cycled
