Problematic brain, cnc guidance
Discussion in 'General Talk' started by CentrepeiceCreations, Jan 10, 2024.
  1. CentrepeiceCreations
    Hello to the community of openbuilds,
    I have a question, give it may not be someone has come across as of yet but hoping so.. I want to know why my nema 23 2.45nm stepper motors are jamming ( thus not turning), I have tried alot of things even returning parts to shop for diagnostics with no prevail however a new controller which still results in same behaviour, I would like to ask what is the relevance of steps permm vs microstepping as motors jamm with 8th microstepping and 300steps permm, but not with 200, same when I change over to 16th microstepping with say 700 steps permm but don't jamm when paired with 500 steps,
    This seams to be the only thing I can change for as motors not to jamm, Has anyone had this issue, is anyone laughing at the amature that is I haha,
  2. CentrepeiceCreations
    Also to add this machine work fine with multiple cuts with 1/8 micro with 400 steps per Mm until it didn't?
  3. Misterg
    Misterg Veteran
    What controller are you using?
    What sort of speeds (mm/min) are you trying to achieve?
    What GRBL settings are you using? (acceleration in particular)
  4. CentrepeiceCreations
    Hi , my Max rate is 4000mm/min and my acceleration is 300,
    Using a spark prov5 controller grbl, with cncjs as my output
  5. David the swarfer
    simple, you are trying to go too fast
    slow down the max rate settings till it works reliably
    Alex Chambers and Misterg like this.
  6. CentrepeiceCreations
