Producing 3D relief's for free.
Discussion in 'Other Software' started by Tweakie, Feb 19, 2014.
  1. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Mach1 Filter.exe.
    Mach1 Filter is a little known and often overlooked, free, stand-alone, Windows based application which can be used to create the necessary GCode tool-path for producing Lithophanes, 3D Relief’s and also laser, raster scan images etc.
    It was written a few years ago and is pretty basic (without all the bells and whistles often found in more up-to-date software) but it still does a good job, and can accept HPGL, JPG & BMP format images.
    As with most software, to obtain the best results, a little practice is required to judge the correct brightness / contrast / sharpness for the original image but it is quickly mastered and for those wishing to try, it can be downloaded from here Mach1Filter
    This is just an example of a 3D relief reproduction working from a JPG depth-map image.
    Tweakie.
    crispin, Evan F, GrayUK and 1 other person like this.
  2. Tweakie
    Moderator
    Hi Justin Time,
    It’s probably best suited for router use.
    However, it can create the GCode for raster scan reproduction of DXF’s with a laser simply by using the machine’s Z axis direction pin as the laser trigger (small change to ports & pins configuration if using Mach3).
    I am not sure if it can produce anything useful for use with an impact magnet tool – perhaps one day I will give it a try.
    Tweakie.
    JustinTime likes this.
  3. Mark Carew
    Nice find @Tweakie Thanks for the share
  4. Johnnythehammer
    Can I view the converted file with Artcam express? I tried with no luck.
  5. Tweakie
    Moderator
    The converted file is Gcode so you would be able to use any Gcode viewer.
    Tweakie.
  6. Ronald4418
    Ronald4418 Well-Known
    I tried in on my Windows 7 desktop and while the program loads and starts to process an image. It always seems to stop. Is there limits as to the size of an image being used or am I missing something?
    Anthony Bolgar likes this.
  7. Anthony Bolgar
    Anthony Bolgar Journeyman
    I have the same issue, it just seems to freeze.
  8. Ronald4418
    While costing a few dollars as opposed to Free. Bmp2CNC is another 3D Relief creation software that I've worked with for years. I don't have any examples to show as other than creating GCode the actual files are saved in the .STL Format and therefore I can't share them here as they're to large.
    Joe Santarsiero likes this.
  9. Ronald4418
    Compared to the $4200.00 for a year that Artcam costs and because it will work without issues, unlike Mach1 Filter. $45.00 and the fact that it works with all versions of Windows without any issues. Seems to be a very good compromise in my book.
    If Free is a prerequisite, than might I suggest that you look in the various Open Source Registries as I am quite sure that there are plenty more options available. But you can forget about any idiot proof point and click remedies.
  10. Davidoe
    Davidoe New
    The creation of 3d reliefs begs the questions "How to create depth-maps in the first place?" and alternatively "Where are the depositories for maps already created?"
    nportelli likes this.
  11. hairyMug
    hairyMug New
    I tried this on a windows 10 PC and it just manages to process a long time and use 30% of the processor and create a huge file (2gb+) before freezing...
    >> 8gig memory with I7 processor
    What are the image specs?? i.e. size and resolution?
    You may want to check out:
    "HalfToner" by Jason Dorie ; Many adjustments to fine tune and runs very fast...
    "Extrudy" lets you set profile of cuts (a bit of a learning curve)
    #11 hairyMug, Mar 24, 2017
    crispin likes this.
  12. nportelli
    nportelli New
    I know this is a very old thread...and I don't really need the program mentioned. But like Davidoe, I'd like to know if there are programs that generate images like the one shown.
  13. David the swarfer
    @nportelli @crispin
    I have been using this
    dmap2gcode
    to create lithophanes but I am sure it will do reliefs, just fiddle with the settings till it works.
    a warning though, such cuts can take a long time (-:
    crispin likes this.
  14. GrayUK
    Haven't seen them for ages. I remember watching a few videos on Youtube quite some time ago.
    Thanks for the memory jog. :thumbsup::)
  15. crispin
    crispin New
    :thumbsup::D:thumbsup:
  16. crispin
    crispin New
    Depth Map Cutting is what many robocarvers want to do on their table builds and dmap2gcode has many settings to fiddle for sure but it's still easier for photoshop users to master than learning another new 3D vector application. "Image-to-gcode" is deep!
    so.many.settings. set them all to match the imagematerialcutter resolution for the job and I suspect it can carve with quickness.
    "When LaceBounding is not None, slopes greater than Contact angle are considered to be "strong" slopes, and slopes less than that angle are considered to be weak slopes." is what now?
    remember:
    "just fiddle with the settings till it works"
    Image-to-gcode
  17. David the swarfer
    it affect how fast and accurately the slopes are cut. (-:
    I suggest you get some insulation foam and experiement. the foam can be cut very fast and is relatively cheap (or you can use discarded molded polystyrene packing).
    one thing to watch is the size of the input image. this affects the 'pixels per stepover' and is easy to change by scaling the image in GIMP or Irfanview or similar.
