Prusa i3 (Acrylic frame with OB rods)
Discussion in '3D printers' started by dddman, Feb 6, 2015.
  1. Mopar32985
    Mopar32985 Well-Known
  2. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    Are your end stops connected as so?
  3. Mopar32985
    yes sir the little led on it even lights up when i push on switch
  4. Mopar32985
    These are how mine are now
  5. Robert Hummel
    Moderator
    Look at the drawing closer and then look at the pin out of your endstop
  6. Mopar32985
    Only difference i see is the endstop is using the other neg close to the positive not the one closer to the signal
  7. Robert Hummel
    Moderator
    Heads up for motor setting and esteps
    X and Y axis step setting is 80
    Z 400 and esteps start at 720
  8. Robert Hummel
    Moderator
    Correct ;)
    It makes a difference not sure why but it does
  9. Robert Hummel
    Moderator
    You may have to change a setting because my file works with them wired as per the drawing
  10. Mopar32985
    awesome that where do you set those settings. Also where do i set the steps per and the and microstepping or do i just leave that stock
  11. Mopar32985
    i will swap that wire so its the same np Thanks
  12. MCSCODER
    MCSCODER New
    I have a 600 watt one and only supplies a max of 12 amps on the 12 volt rail.
    Normally that is a combined wattage of all the outputs which includes the 3.3 and the 5 volt rail. Most of those MK2 heatbeds can draw up to 16 amps, which the xbox 360 power supply can deliver, but, all other electronics are powered off of a separate power supply.
  13. Mopar32985
    @Robert Hummel hey man did you get a chance to upload your code I didnt see it. Thanks!
  14. Robert Hummel
    Moderator
    Saving it now ;) will upload in a bit gotta give the kids a bath
  15. Mopar32985
    Thanks man!!
  16. Robert Hummel
    Moderator
    open the OBi3 ino file in the arduino software
    Mopar32985 likes this.
  17. Mopar32985
    You the man
  18. Mopar32985
    Sweet now the home switched are working!!! only problem i see now is the z axis had chatter in it when it moves. Any input
  19. Robert Hummel
    Moderator
    You may have to change the hotend thermistor settings as mine is set for the e3d
  20. Robert Hummel
    Moderator
    Be sure to square the z also tune the driver to about 75% on the pot
  21. Robert Hummel
    Moderator
  22. Mopar32985
    Nice thanks running smooth now man o man :)
    Robert Hummel likes this.
  23. Mopar32985
    @Robert Hummel setting are great man im supper happy with my first print. After the print i realized that my 4 bolts wernt even tight holding the extruder to the x axis rods. Tomorrow lots of tuning 20150415_002244.jpg
  24. Mopar32985
    Has anyone here tried printing ninjaflex through the wades extruder. I want to try it but might try semi flex instead so flexable but not as much.
  25. Robert Hummel
    Moderator
    I have some just have not tryed it yet
  26. Mark Carew
    Great looking first print @Mopar32985! I remember my first print looking more like a bowl of spaghetti :ROFL:
    Keep up the good work my friend
  27. Mopar32985
    Thanks☺ @kram242 i appreciate it. I found out i was using the wrong feeler gauge. @Robert Hummel has been helping me tweak it and the print right now is looking great
  28. Mopar32985
    So this is what im getting now looking better but doesnt like the thin lines. Sides are ok but still not perfect. 1429153090817367536017.jpg 1429153114453-848120983.jpg
  29. Mopar32985
    :banghead::banghead::banghead::banghead::banghead: Haha the problem this whole time was my small gear was every once in a while slipping. So i grinned a flat spot in the shaft of the stepper much beeter so far trying to print another small gear
  30. Mark Carew
    Good find @Mopar32985 I hate it when it something small like that but love it when I find and fix them! :thumbsup:
