Raise Z on Stop
Discussion in 'Control Software' started by IsuzuCrewCab, Feb 23, 2021.
  1. IsuzuCrewCab
    Hi,
    It is possible to raise Z automatically on Stop? I usually remember to do it but sometimes forget. Problem occurs if stop the cut to make a change to the design, reload the file and then restart; if I have not remembered to raise Z, it may cut through the piece on the way to restart the cut.
    Steve
    See gnea/grbl - recompile Grbl with the Door switch and Parking motions disabled, then use the Door switch to pause the machine.
    Also read through Door Open / Feed Hold Behavior
