regular relay module to switch spindle on
Discussion in 'General Electronics' started by IFlyRocketsAtHome, Feb 24, 2025.
  1. IFlyRocketsAtHome
    Hey all !
    I just fiished setting up my 1515 lead cnc machine, and am now trying to hook up a regular relay from my blackbox x32 controller to the spindle.
    How can I blug these modules together ? I am guessing the "relay1" port on the blackbox acts as a physical switch...
    See pictures of the relay I am talking about...
    Thanks a lot !
    T.
    Please use our recommended relay: docs:blackbox-x32:connect-dewalt-iotrelay [OpenBuilds Documentation] - safe mains isolation of mains voltages from the operator for safety (preventing lethal danger), safe isolation between control signals and mains side (preventing damage to controller) and correctly rated for the load (proper relay for spindle current)
    If you are unsure how to wire this module, that should tell you to consider not doing it, call an electrician or other qualified professional in for help.
