Replace Delrin Mini V Wheels
Discussion in 'CNC Mills/Routers' started by jeffmorris, Mar 14, 2025.
  1. jeffmorris
    jeffmorris Journeyman
    Should I replace Delrin Mini V Wheels after using my modified LEAD CNC Machine 1010 for several years? I found out that the router mount carriage was a little bit loose and while tightening the Eccentric Spacers, I found out that the wheels may be worn out.
    Do an inspection, does the wheels look worm or still in good condition (pictures if you'd like our take on them)
