Reprendre une gravure suite à un arrêt/Resuming an engraving after a stop
Discussion in 'CNC Mills/Routers' started by Bertrand78, Mar 20, 2020.
  1. Bertrand78
    Bonjour.
    J'aimerai savoir si après un arrêt machine, (fin de course manipulé par inadvertance) il est possible de redémarrer à l'endroit où c'est fait l'arrêt avec OBC V1.0.213.
    J'ai malheureusement été obliger de reprendre 6h00 de gravure.
    Merci d'avance pour la réponse.
    Cordialement.
    Bertrand
    Traduit avec DeepL Traducteur / Translated with DeepL Translator
    Good morning.
    I would like to know if it is possible to restart after a machine stop, (limit switch inadvertently manipulated) at the place where the stop was made with OBC V1.0.213.
    Unfortunately, I had to restart after 6 hours of burning.
    Thanks in advance for the answer.
    I'm looking forward to hearing from you.
    Bertrand
  2. Rob Taylor
    Short answer? No. Emergency stops do not maintain machine position. It's impossible to know how many steps were skipped as the machine stopped itself.
    If you probed the part you were engraving and started from a fixed origin, then you can re-find it and re-start the process. If you just set up the workpiece roughly and hit go, it's unlikely.
    On the other hand, if your laser kerf is quite thick, you may be able to eyeball its position and continue from where you were. It's possible, but unlikely.
    Hopefully this translates well!
  3. Bertrand78
    Réponse courte et rapide et qui répond parfaitement à ma question.
    Je pars toujours d'une origine fixe, cela me permet de repartir exactement du même point.
    Merci
    Short and quick answer that answers my question perfectly.
    I always start from a fixed origin, this allows me to start from exactly the same point.
    Thank you
