Rounded v carve corners
Discussion in 'OpenBuilds Forum Help' started by anewell006, Aug 22, 2024.
  1. anewell006
    I keep getting rounded cover corners when doing inlays on my lead 1515 with z height mod. What is causing this?!? IMG_7052.jpeg IMG_7051.jpeg
  2. Giarc
    Is the material a uniform thickness? How are you determining the Z zero point? Is your spoil board surfaced and parallel to the gantry?
    Or incorrect taper in tool setup. Make sure angle of v bit matches angle specified in tool library
    Giarc likes this.
  4. anewell006
    Spoilboard is surfaced, spindle is trammed. Material is surfaced. Z zero set w probe
  5. Giarc
    Zeroed on top the wood, or the spoil board? I usually zero on the spoil board for everything except V carves because issues like this arise if the material is not the thickness it is expected to be.
    Also, as Peter said:
