router bit to cut v-slot in custom materials
Discussion in 'CNC Mills/Routers' started by mrrobo, Nov 14, 2020.
  1. mrrobo
    mrrobo New
    Hi,
    This is my first post so please feel free to offer constructive advise.
    I would like to know if there exists a router bit to cut the v-slot shape. I have a project that uses extruded HDPE boards in which I would like to cut groves that match the v-slot extruded aluminum.
    Thank you in advance.
    -rob
  2. sharmstr
    I've never seen one. That doesnt mean it doesnt exist though. There's plenty of places to get custom bit made. Or maybe even grind down a 90 degree v-bit.
    mrrobo likes this.
  3. Rob Taylor
    Almost certainly exists. Or make a 45 degree fixture, use a standard end mill. A quick clearance slot at the bottom either before or after, done. On sheets, make a 45 degree holder for the spindle. No law saying the work has to be flat or the machine has to stay stock at all times.
    mrrobo likes this.
  4. Giarc
    90 degree v bit 2 Flutes V Groove Solid Carbide 90 Degree. Create a slot 6.79ish mm wide 1.80mm deep and then come back around the edge (engraving pass on the border lines) with the v bit at that depth. I do not see why this would not work unless I am totally misunderstanding the question. Best of all, HDPE is easy to cut and should be quick with one pass at a depth of 1.185 (1.8-0,615). Give it a shot on some scrap material. An option would be to cut on the inside 0.1mm and 0.1mm deeper to be sure the edge of the grove is clean.
    mrrobo likes this.
