Router doesnt turn on at start
Discussion in 'General Talk' started by joefroooo, Dec 28, 2024.
  1. joefroooo
    joefroooo New
    I replaced my computer and loaded OB latest software to control my black box controller. When I generate a new program using OB CAM the router will not turn on at the start of the program. The IOT will turn on when I use the wizard to cam out a surfacing cut so I know everything is working. The CAM generating from my drawings is not giving a command to start at beginning of turn off at end
    How do I add that function to all the files generated by the software? I dont see a section in the Grbl settings to add that command. I did work that way on my old computer.
    Joe in STL
    CAM > Settings tab > Settings button > add a router / spindle as tool add-on > Save
  3. joefroooo
    joefroooo New
    That was it Peter. I guess I didn't hit save when I set it up. Thank you for the quick response to my inquiry.
    Joe
