Router11 install on openbuilds 1515
Discussion in 'CNC Mills/Routers' started by Adam T., Feb 14, 2023.
  1. Adam T.
    Adam T. New
    I am brand new to CNC machines, I just finished building the 1515 and everything seems to run perfectly all the way through the hello worlds air cut. I know how to mount the router, but my question is where exactly do I set the Router11 in place in the lock? Thanks!
    Position is adjustable - you'll typically set it up as low as possible, so you can use the shortest endmill possible - that way you have the most rigid setup for a particular job.
    Also see below around the 45s mark
    Esme likes this.
  3. Adam T.
    Adam T. New
    So how does the machine know where I set the router, as in where the bit is to get proper depth in the cut?
  5. Adam T.
    Adam T. New
    aaah! I have the XYZ prob, so with that and the jogging I can tell the machine where the bit end is?
    Yes, every time you start a job!
  7. Adam T.
    Adam T. New
    Thank you!
