Running into Z endstop issue at start of the job
Discussion in 'OpenBuilds Forum Help' started by Nephsol, Mar 15, 2025.
  1. Nephsol
    Nephsol New
    Hello everyone.
    I do have a problem using a big piece of wood.
    Everytime i run a job, the machine travels to the starting position (x/y). Afterwards it rises Z before going into the wood.
    Normaly that's ok but because of the height of my current wood, the z endstop is hit.
    Is there a way to stop the machine of doing this anyway useless move?
    I'm using fusion 360.
  2. Nephsol
    Nephsol New
    Ok i found the problem. After some trail and error i found the retraction hight in Fusion360 to be to much.
  3. David the swarfer
    yeah, Fusion360 has a million settings and many of them are defaulted or calculated from other settings, up to you to check that things like retract height are sensible before running the code (-:
    I have run jobs where a retract of 1mm was nearly too much, took a lot of careful thinking and cross checking before hitting GO
    Nephsol likes this.
