sacrificial board
Discussion in 'CNC Mills/Routers' started by marlin adams, Sep 26, 2021.
  1. marlin adams
    I did a search and I could not really find a answer so I post the question here. When I flatten the sacrificial board I know my cnc will not reach all the way if I measure and cut the board to fit the full length and width of the cnc the X,Y will not reach and I will have basically have a raised end all the way around. The flattening bit will be 1 1/4" across. So do I need to just measure or mark on the board where the outside cutting edge will be and just cut my board that size? I have 1/2 sheet of 3/4" birch plywood and using it at my sacrificial board
  2. jeffmorris
    jeffmorris Journeyman
    Please don't use birch plywood and use MDF board.
    Couple options:
    1) knock down the remaining edge after surfacing, with a handplane or sander
    2) learn to love the raised edge as a precision alignment edge to butt stock up against before clamping - its great for that!
    3) install a smaller sacrifial 1/4" MDF spoilboard of the exact dimensions on top to provide clearance
    Main spoilboard = full machine bed size - do not shrink it - it plays a role in holding the machine rigid too...
    marlin adams and RV6APilot like this.
  4. marlin adams
    Cool, didn't think about a built in edge. And with premium birch plywood being expensive I will go with MDF
    Thomllama likes this.
