scale seems off - new user
Discussion in 'CNC Mills/Routers' started by matthewsorrells, Jun 8, 2023.
  1. matthewsorrells
    I'm a new user to openbuilds - I have used easel for more than a year now and the machine i purchased second hand with an arduino controller. I dont understand a lot about this thing, but i have used it to make signs and things in easel with no problem with scale. I'm trying to do a 3d carve, and used aspire to design something that is 10 inches square, but when i tell openbuilds controller to run program or check size, it acts like the project is 10 mm instead of inches, however when i check if 100 mm really is 100 mm it is within .05 each time. Can someone direct me as to how to fix this please?
    openbuilds 1010 machine
    custom arduino controller (someone else built it, but its worked fine up until now)
    remember, I'm a noob. thank you.
  3. matthewsorrells
    again, total noobie. i took the saved g code and opened it right up in the controller. no post processing. can you elaborate?
    Follow the link provided - you cannot export gcode out of Vectric without a Post (its not a seperate step)
  5. matthewsorrells
    i downloaded one and installed it, but nothing changed. the link you provided is confusing. does it happen automatically after install?
  6. Alex Chambers
    You have to put the post processor in the post processor folder (or MyPostP folder - if there are any post processors in this folder they will be the only ones that Vectric will find) in the vectric software - sorry not on the PC with Vectric installed to show you where that is, but start by looking for "Application Data" folder on your PC - then re-start Vectric. Then Vectric will include that post processor in the list of options when you save a toolpath.
  8. matthewsorrells
    so ive got it closer.... the cnc thinks my 10" project is around 8" now, so thats better but not right. Peter, I've read that but i cant seem to understand what i need to do. i have vectric 10.5 any help is gladly appreciated.
  9. Peter Van Der Walt
    Should have the Openbuilds post built in, as per the first section of the aforementioned documentation (download post is for older versions)
    Also check Calibration from CONTROL > Wizards and Tools > Calibration menu
  10. matthewsorrells
    I am using the openbuilds post processor. using the calibration wizard, it is set to move 100 mm when i say to move 100 mm in each direction. it does exactly as i tell it to, just when the project is loaded and i click check size it moves 8" wide and 7.75 inches tall on a 10" project
  11. Peter Van Der Walt
    Post the files. Gcode, vectric both. If it looks right in the preview it's the machine. If its wrong in the Preview its in your CAD/CAM setup
