Hi, I have a little problem, I want to set the work origin to the center of my piece. I looking for that because my bit is too short to go through all my piece. So I decided to make half pass on one side, and return the piece make the second pass. But there is a little Offset on my final piece. I design my piece with inkscape and use camopenbuilds to convert to gcode. So my question is : Is it possible with camopenbuilds to set the origin to the center of the piece instead of the left corner ? I hope I'm clear enough, and sorry for my english. David
Problem solved. I set the negative offset on inkscape. And now it works as i want. I share my screenshots. Thx
