Sim Rig with Traction Loss
Discussion in 'Other Builds' started by Mazda21, Mar 30, 2024.
  1. Mazda21
    Mazda21 New
    Hello Everyone. Not sure if this is the right Forum to post, But the concept is the same.I would like to build a Traction Loss Platform like this:
    upload_2024-3-30_9-50-33.jpeg This is the text in the post:
    " For the motor/actuator, I'm going to use the same motor that I use for the 4 legs actuators. They are 180w integrated servomotors. 'Integrated' means that the driver are built in inside the motor assembly.
    But for the TL, I'm going to couple the motor with a 'linear motion guide rail' that I found on aliexpress.
    I don't have a picture but this linear rail perfectly match the motor that I am using (nema 23 size). With 5mm pitch, the combination can push up to 80kg of force at low speed and around 60kg at around 100mm/s (given the power is only 180w) "
    I would like to Buy from this site, because it looks like I might find what I'm looking for. I can build the Platform, but I would like some guidance on the motor, rail, and software.
    Thanks for looking, and Thanks for any input. Bob.
