Solid V wheel Kit (how many shims?)
Discussion in 'CNC Mills/Routers' started by Vernon Fowler, Jul 20, 2020.
  1. Vernon Fowler
    The assembly video for the Workbee 1510 shows 1 shim needed. The V wheel kit shows 2 shims. which is correct?
    Only one in between the bearings. An extra shim is sometimes used between the wheel and spacer (eccentric or alu), but depends on which assembly you are putting together, most needs the extra 1mm spacing, some does not.
