Spindle
Discussion in 'General Talk' started by Stefano G., Jan 20, 2025.
  1. Stefano G.
    Buonasera, è la prima volta che lavoro con una CNC per cui sicuramente farò delle domande stupide.
    Ho comprato una macchina da Openbuild e utilizzato il Blackbox32. Tutto quello che deve fare la macchina e di seguire un tracciato, e queto sono riuscito a farlo tranquillamente, poi pero dovrei attaccare un motorino, quello che comunemente viene chiamato spindle, che lo utilizzero co e encoder per lavanzamentp del lavoro. Avevo fatto delle prove con una algtra scheda, dove cera luscita direttamene "spindle" per cui nessun problema, nel Blackbox32 non riesco a capire come lo devo collegare. Grazie dell' aiuto.
  3. Stefano G.
    Sorry, i am very stupid. My PC has translated directly my post in Italian.
    I retry.
    Is the first time that i use an CNC machine and try to usen Gcode.
    My question is very simple. I need to connect a simply gear motor to the machine, in order to obtain a signal form an encoder connected.
    IO have done some trials with another board, where there is a plug named "spindle" and with command M3 my motor is running.
    I have buyed a CNC at Openbuild and the controller Blackbox32, but i haver not idea where connecting my gear motor. That is all.
    Please, can yoiu aid me?
    Thank you in advance.
    We have logic signals for driving a IoT relay docs:blackbox-x32:connect-dewalt-iotrelay [OpenBuilds Documentation], or a VFD spindle
    Gear motor: Might need to add a motor controller in between (PWM signal > motor controller > motor)
  5. Stefano G.
    Thank you. I try to guess. If i connect an 24V rele in the plug "Tool", at the command M3 my rele switch to on, at the command M5,the 24 V rele switch off. Is correct?
    Relay is for signalling (VFD enable / fwd / rev, and Plasma Enable etc). Not meant for powering loads
  7. Stefano G.
    Yes, i know, but i can connect an optoisolated Relay, In this case noload is applied, or i can use a simple driver for DC notor.
  8. Stefano G.
    Sorry, another question, in wicth way the direction is setted?
  9. Peter Van Der Walt
    Yes you can use an isolated relay, or a motor controller that matches your gear motors requirements. We provide standard logic signals (enable, PWM, even 0-10v) just find a driver that accepts it (PWM most likely)
    SPDT relay - used for VFDs FWD/REV inputs, flips between NC and NO for M3/M4 (or other way round, check with multimeter) but NB only for signalling (Dry contact relay, not a power relay)
  10. Stefano G.
    So, if i have understood, in the plug named "Tool", normally i have 0V betwenn Gnd an ENAB, at the comand M3 i get +12V, at the command M4 -12V, at the command M5 return to 0V. Correct?
  11. Peter Van Der Walt
    No, its logic signals. Not 12v!
    0v for off, 3.3v 10mA for on.
    Tool Enable = 0/3.3v binary on/off (used to arm a tool)
    PWM = 03.3v variable duty cycle pulse train (used for speed for controllers that support PWM input for speed)
    0-10v = analog 0-10v scaled voltage for spindle speed (typically VFDs) - but very low current, again just a SIGNAL
    DIR = dry contact, no voltages, its contacts of relay moving between NC and NO
  12. Stefano G.
    Ah ok, Is a TTL Logic.
    Comand.M3 plug "Tool" go on (3.3v), Plug "Pwm" pulse berween 0 and 3.3 ( depending by the value of command S, plug "Relay2", no movement (remain in No), command M4, all the same but the replay 2 switch in Nc.
  13. Peter Van Der Walt
    Essentially yes, but 3.3v (TTL was mainly 5v back in the day) - but same, just a logic signal
    "tool plug" = TOOL ENABLE yes docs:blackbox-x32:layout [OpenBuilds Documentation] (Section 2(h))
    Always a 3.3v pulse train, not 0 to 3.3v - but the width of active section the pulses changes (duty cycle)
    Essentially yes
  14. Stefano G.
    Ok, for the Pwm i know the method, regarding the 3.3 volt i remember that in ttl Logic the 3.3 v is the minimum value to get the commutation. Thanks you . Very very kindly,
  15. Peter Van Der Walt
    Yes, but beware to not connect the 3.3v pins to higher voltage devices (like a relay with a 5v pullup, or a motor driver with stray voltage on the input pins)
  16. Stefano G.
    Ok, thank you, if you have some suggestion, regarding the tipe of driver, please, le me know.
