Spoilboard wizard issue
Discussion in 'Control Software' started by Joshuagr8_intx, May 22, 2021.
  1. Joshuagr8_intx
    I'm running the wizard, only value I've changed is the size of the work area, I've tried this three times, staryt out with good results and then sometime between 6 and ten inches it raises the z axis by exactly a mm, I'm new to this should I just try generating the toolpath in fusion?
    Unlikely to be gcode related, maybe a nick in a rail causing the jump? Or some other mechanical cause
