Start and Stop
Discussion in 'General Talk' started by ADize, Sep 30, 2020.
  1. ADize
    ADize New
    I am new to open builds and have built a x, y table using the black box set to arcos 55 for a multi head tapping system. I am tapping 3 parts at one time, each part haves 3 holes. I would like to program it to stop after each hole and wait for input, I.E.. any key. Can the software do this
  2. Rob Taylor
    grbl accepts M0 mandatory stops, which pause the program until cycle start or resume is pushed again.
  3. ADize
    ADize New
    Thank you, that does work, it gives me a pause, then I click, to get the run, then have to click again. is there a less click method
  4. David the swarfer
    there is a key that is bound to 'run' (I have forgotten which one), you can press that. having 'any' key as 'run job' will never work, much too unsafe and how would you jog etc?
    or you can connect a key to the run/pause pin on the controller, my early Blackbox does not have it available but maybe the new version does?
  5. phil from seattle
    phil from seattle Journeyman
    Cycle/Start and Feed/Hold inputs - you can wire each of those to buttons to get start and stop right at the machine.
