Still Confused About Feeds and Speeds
Discussion in 'CNC Mills/Routers' started by Scott Thompson, Feb 2, 2021.
  1. Scott Thompson
    Hi all,
    I have used various feed and speed calculators and I am getting various results (see below). the end mill that I am using is a 1/4" 2 flute downcut. The chip load for this bit on MDF is between .013 and .016 in. Some calculators say my feed rate should be up to 8000 mm/min (315 ipm) while others say between 1000 and 2000 mm/mm (40 ipm and 80 ipm). Can some help this confused newbie?
    Thanks,
    Scott
  2. Alex Chambers
    Some calculators are intended for industrial machines which are much more rigid than our hobby machines. 1000~2000 mm/min is more realistic.
  3. Giarc
    I have found that about 2500 mm/minute with a depth of cut of half the diameter of the end mill works well for me for all types of wood and plastic products I cut. My main variable is the RPMs of the router. I adjust it if it sounds like it is struggling, or if it is spinning too fast and making dust not chips.
    Alex Chambers and sharmstr like this.
  4. Scott Thompson
    Thanks for the info guys
    Alex Chambers likes this.
