stl to grbl
Discussion in 'Control Software' started by doroni, Mar 7, 2023.
  1. doroni
    doroni New
    Hi guys
    I am new in cnc field but use 3d printer for many years
    I design my models with OpenScad
    For one of my models I need transparent parts so I decide to cut them from plastic panel using cnc router
    I bought a Sain Smart 3018 pro cnc router and assembled it
    My problem that I don;t find the right way to convert the stl file for the grbl code
    I download a pyhton script that convert the stl to ngc file but it does not run on the cnc router gcode app
    when i esit the ngc file i see a remark that this is gcode for linuxcnc so it is not work for grbl
    Can you guide me what is the best way to preform the stl to g code ?
    Regards ahead Doron
  3. David the swarfer
  4. doroni
    doroni New
    Thanks for help
    Will try to use it
    Doron
  5. Gary Caruso
    Another option, Estlcam supports STL with no conversion, and has grbl post for cam or can run Arduino type machine directly.
    Gary
    doroni likes this.
  6. doroni
    doroni New
    Hi Gary I will try it
    from first look and quick one looks good
    Doron
  7. Gary Caruso
    There is a YouTube video on how to do it. Link on the Estlcam site
    Gary
  8. SethCNC
    SethCNC New
    Carveco Maker also does this function
  9. doroni
    doroni New
    will try it too
