surface tool
Discussion in 'General Talk' started by Raymond Starbird, Nov 11, 2020.
  1. Raymond Starbird
    I can not get my surface wizard to work on my 1515 lead. i type in my information and hit proceceed and nothing happends
  2. Scott Lay
    Scott Lay New
    Not in ALARM by chance are you? can you jog the machine in manual mode?
  3. Raymond Starbird
    yes
  4. Raymond Starbird
    I have already run a few carves
  5. Scott Lay
    Scott Lay New
    Sent you a message in FB
    Make sure all values are actually filled in. The example text is a gray, entered text is black.
  7. FrankM2020
    The surface wizard wont work for me either. used vcarve to create a flattening job, this worked but would prefer to use OB wizard.
    Double check the values you type into it :) it works: did a quick test and recorded screen for you.
  9. Scott Lay
    Scott Lay New
    Peter, I spoke to the gentleman that started this thread. One thing that he did not mention in here was the "white screen of death" that he gets when trying to run the surfacing wizard. He has the 1500x1500 machine and the only time I have seen the white screen is when the OB software is unable to handle the size of the program.
    Like typoing that to 15000mm or entering 0.25mm as endmill thinking about a 1/4" yes
