SVG into Openbuilds CAM
Discussion in 'Control Software' started by IainP, Feb 8, 2023.
  1. IainP
    IainP New
    Hi,
    I have an SVG I created in Inkscape that I want to cut, the SVG looks like this in Inkscape:
    Importing that into CAM gives this:
    So its lost the fill and looks like it wants to cut every line.
    What am I missing?
    thanks,
    I.
  3. Giarc
    Sadly that is what inkscape does. It took me a while to figure that out when I would import an .svg into Fusion 360. Now what I do it go in to Inkscape, remove the fill, then delete one of the sets of lines for each item. Then I can rescale it to whatever size I want with the single lines. Their may be a better way to do this, but I have not been smart enough, or patient enough to find it.
    Here is your picture on the left, and I drew a yellow area to the "x" you need to click on to remove the fill if you want to give that a try so it will look like the one on the right.
