Table Dimensions
Discussion in 'General Talk' started by Rink, Mar 23, 2021.
  1. Rink
    Rink Well-Known
    Good afternoon.
    What table surface dimensions are needed to support the LEAD 1010 and the LEAD 1515?
    I know the work area and dimensions of the machines themselves but, realistically, how much table surface so that I don't have any motors or bolts hanging out in mid-air?
    Thx, rink.
  2. Rink
    Rink Well-Known
    Good afternoon.
    Thx, rink.
  3. Rick 2.0
    At an absolute minimum you should add 140mm each direction to the machine dimensions. Truly though you're safer adding 220mm each way as they have done in the OpenBuilds Table Series | OpenBuilds. This leaves you room to enclose the system should you get the desire.
  4. Rink
    Rink Well-Known
    Thank you.
