Tabs for circular pieces
Discussion in 'CAM' started by David25, Oct 4, 2021.
  1. David25
    David25 New
    Hi,
    I used openbuilds cam for several month now, everything is ok but when i draw a circular piece, tabs not applied. I set different distance (1 - 50 mm), but no tabs. Is it a known problem or a mistake from me ?
    Thx for replies.
    David
    We don't currently have the ability to tab on non-straight sections but if you experiment with Tab Width and spacing enough you may get lucky, you want to make the tabs < segment of the curve
    For more advanced work, checkout Vectric or Fusion 360 as upgrades
