Text writing problem
Discussion in 'OpenBuilds Forum Help' started by M3hdi, Nov 22, 2023.
  1. M3hdi
    M3hdi New
    Hello,
    I’m encountering a problem with text creation on the cam.openbuilds.com website. When I insert my sequence of numbers, they no longer appear. Do you know why and can you help me?
    Best regards,
    Please provide more details. Which font, text, size etc so we can try and see if it does it for us too
  3. M3hdi
    M3hdi New
    I didn’t specify because I encounter this problem with the ‘Text’ button with any font, text, and size. Nothing is displayed. However, when I make a circle or a rectangle, it displays correctly.
  5. David the swarfer
    yep, no text for me either.
  6. fthomas96
    fthomas96 New
    I have the same problem with text
    i did the update and only the circle and rectangle work
    Fixed: Just make sure to clear cache/cookies and hard-refresh the page to load the latest code.
    Rick 2.0 likes this.
  8. Loggy
    Loggy Well-Known
    It is likely unrelated, but I can get the same issue when using Easel if my selected tool bit is larger in diameter than my text 'elements' are wide.
    ie. a 3mm bit can't cut something that is <3mm in width. And Easel simply leaves it out of the design until I either choose a smaller bit or make the elements wider.
    HTH.
    BTW I should now try this CAM GCode Creator that I've never seen before ;)
  9. Peter Van Der Walt
    No wasn't a setup mistake, just an expired Google Fonts API key.
    Loggy likes this.
  10. Loggy
    Loggy Well-Known
    Ah goodo.
  11. David the swarfer
    Buda 300 font does not work for me, others do
  12. Peter Van Der Walt
    Any console errors?
  13. David the swarfer
    Code:
    blur viewer-pause.js:1:225
    Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://mymachine.openbuilds.com:3001/api/version?_=1700927843020. (Reason: CORS request did not succeed). Status code: (null).
    downloadable font: Glyph bbox was incorrect (glyph ids 93) (font-family: "Buda" style:normal weight:300 stretch:100 src index:0) source: https://fonts.gstatic.com/s/buda/v29/GFDqWAN8mnyIJSSrK7ILrg.woff2
    downloadable font: Glyph bbox was incorrect (glyph ids 7 42 68 71 87 168) (font-family: "Cardo" style:normal weight:400 stretch:100 src index:0) source: https://fonts.gstatic.com/s/cardo/v19/wlp_gwjKBV1pqhv43IE.woff2
    Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://mymachine.openbuilds.com:3001/api/version?_=1700927843021. (Reason: CORS request did not succeed). Status code: (null).
    Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://mymachine.openbuilds.com:3001/api/version?_=1700927843022. (Reason: CORS request did not succeed). Status code: (null).
    the cross origin thing occurs every .5 seconds or so.
    bolded stuff is only when i insert Buda text
  14. Peter Van Der Walt
    Cors thing is just noise (CAM still checking for CONTROL integration to be revisited)
    Will investigate Monday
