TFE2 CNC Build
Discussion in 'CNC Mills/Routers' started by Mike_Mara, Aug 10, 2025 at 6:05 AM.
TFE2 CNC Build
My TFE2 CNC Build. The TFE was much smaller and all of the gantry plates were 3D printed. Despite this it will happily machine aluminium without issue. So I decided to use that to make the TFE2 which will be all aluminium plates and much larger (1200x800mm machining area with roughly 140mm in Z so I can later add a rotary axis.)
