The gbrl in my blackbox is dead
Discussion in 'CNC Mills/Routers' started by drmore, Oct 4, 2020.
  1. drmore
    drmore New
    Hello Openbuilds Community.
    I have a leadcnc with a blackbox.
    The blackbox has ceased to function.
    Gbrl is missing from its brain. Missing firmware error.
    Was working great then stop mid surfacing operation.
    Followed the troubleshooting and disconnected everything. No change. Tried to reflash. It fails. Tried on a different computer, same story.
    Is it dead or can it be saved. By saved I mean can I fit it at home without needed to return it?
    Jonathan
    Refer to docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] (note the very last step in the documentation)
  3. drmore
    drmore New
    Thanks I'll contact Openbuilds store. Had fingers crossed for some magic button that would resolve my issue. Guess not
    Sadly not. Though while you wait on them, go over all the wiring again. Its usually related to some kind of wiring issue either causing a temporary short, or causing more permanent damage
