This for a rotary axis? any other ideas? brands?
Discussion in 'General Talk' started by Travisd, Nov 13, 2023.
  1. Travisd
    Travisd New
    Rotary Table, 4th Axis 6"
    Would like something that can hold a 10" diameter piece?
    Cbeam build, no y axis, just an a axis rotary setup is the goal.
    I have been looking on ebay too. Has anyone recently purchased a rotary axis and set it to the openbuilds machine?
    Any body familiar with the programing - the degrees?ratio to make sure the axis is inline with the other axis?
    #1 Travisd, Nov 13, 2023
    Checkout LEAD Lathe
  3. Travisd
    Travisd New
    thanks
  4. Giarc
    I built the LEAD lathe referenced above. If you are using Vectric Software, the postprocessor I use works great. It converts mm to degrees. I have the ability to cut up to 8 inches due to how high I built my X axis, and the fact i put it in an enclosure. I may revisit that if I feel I need to cut larger items. My chuck is a 100mm 3 jaw chuck. I made adaptor plates (Adaptor Plates For Non-round Stock For A 3 Jaw Chuck) that mount to the work stock so I can cut items larger than 100mm and do not need round stock. Looking back on it now, I could have saved a lot of money with a 65mm chuck using the same adaptor plates.
  5. Travisd
    Travisd New
    Your build is awesome. I use vcarve, is the post processor your design, or one for the Blackbox?
    I am currently using a bobscnc revolution with vcarve, works well but I would like to build my own. Something bigger and a little more sturdy. Hopefully you would be OK taking some questions if I start my build.
  6. Giarc
    I got the post processor from here: Rotary Post processor I modified it a bit so it posts the finished file in the .nc format. You do not need to if using an OpenBuilds Blackbox. The post processor works as is.
    I am open for questions.
