Tool head voltage out of range
Discussion in 'Controller Boards' started by Anselm Wiskott, Apr 7, 2024.
  1. Anselm Wiskott
    Hi community,
    I am using a Black Box X4 and having an issue with the analog tool head output.
    While the output should range between 0-10V, mine ranges between 19 and 24V when turning the spindle to on.
    Rotating the 10V adjustment screw does not change anything.
    Any suggestions as to what is wrong ?
    Thank you for your help,
    Greetings,
    Anselm
    That indicates the BlackBox's 0-10v output became damaged. Any earlier miswirings or perhaps a faulty VFD that backfed the output?
  3. Anselm Wiskott
    I will write to the seller.
    Thank you for your input,
    Anselm
    That would typically not be covered under warranty. But the 4X might have aged out of warranty already. Havent been for sale in a while
