Travel limited to 1000mm
Discussion in 'CNC Mills/Routers' started by ricklach, Aug 20, 2021.
  1. ricklach
    ricklach Well-Known
    On my new build I have an issue that I am trying to troubleshoot/fix. My new machine has 2600mm of travel in the y-axis. When I manually move the y-axis in either direction it ceases movement after 1000mm from the start point. Can I change that in GRBL?
    See the Soft Limits and Max Travel parameters described in github.com/gnea/wiki > Configuration page - the Grbl wiki is a must-read
