URGENT Help Needed
Discussion in 'General Talk' started by rbrown55, Mar 12, 2024.
  1. rbrown55
    rbrown55 New
    I am trying to cut an order for a customer and my right Y axis keeps locking up and stops moving during the cut it even did it while trying to get the router positioned for a cut after realigning everything. Is their a tech support line I can call I need to get some immediate help as I need to ship this order today
    THere is some what i call wobble sounding noise and a kind of whining as it is moving....there seems to be some extra play in the screw when I try and move it with my hand but not sure wht to try and adjust at this point
  3. rbrown55
    rbrown55 New
    I haven't changed any settings...I'm not that technical lol
    My guess is mechanical at the moment
  4. rbrown55
    rbrown55 New
    7 of the 8 wheels are all tight...one is pretty loose and spins easy by touch.
    If you make a video of the stall we can see if we see/hear anything to give you more clues
    Tight is technically wrong. Just touching is correct. Too tight will damage wheels and cause binding:
  6. rbrown55
    rbrown55 New
    ok i will adjust the wheels
    Is the blue light on the controller box supposed to go off when you turn the power off? Mine stayed on
    Yes, if USB is still providing power
  8. rbrown55
    rbrown55 New
    ok, i did have the usb connected....
    adjusting wheels now and will give it a try
  9. rbrown55
    rbrown55 New
    Video attached….hopefully
  10. rbrown55
    rbrown55 New
    made a video
  11. rbrown55
    rbrown55 New
    Also when I get towards the back of the y axis it has more issues with binding and when I try to manually move the screw to line it up it is a bit hard to move and feels like maybe something is bent....hard to describe
  12. Peter Van Der Walt
    Close visual inspection, perhaps partial teardown.
  13. rbrown55
    rbrown55 New
    I am sorry but what does that all mean?
  14. Peter Van Der Walt
    Means, you gotta poke around there - you' re the only person at the machine - only one that can look and feel and inspect. You may need to take some things apart for a better view / feel.
    Feel where it gets stuck. Listen where weird noises come from. You being there, can check for damage to the thrust bearings, or see if the leadscrew is bent, ot check whether you forgot some spacers during assembly.
  15. rbrown55
    rbrown55 New
    Yea sorry…I misread your comment. Did the video I sent provide any clues?
  16. Peter Van Der Walt
    It doesn't stall in this video
    But the leadscrew sounds dry - spray some Dry/PTFE lubricant (Don't use oil it will degrade the Delrin nutblock)
    The leadscrew might be slightly bent by the whipping we can see, no need to immediately replace, but dial down Max Rate in Grbl Settings for Y to about 70% of current values
  17. rbrown55
    rbrown55 New
    Can you please give me instructions on dialing down the Y value?
    Thanks Peter….is this something I just go into the main settings and change ? I am not familiar with any coding if that is what it takes. I am away from my computer and machine until Thursday unfortunately as I had to take off rather quickly.
    I did manage to get what I needed cut by changing the workspace direction and limiting the amount of movement on the y axis but that won’t work past today
  18. Peter Van Der Walt
    CONTROL > Grbl Settings tab > Scroll down to $111 Max Rate for the Y axis. Change value. Save and Reset when prompted
    Grbl v1.1 Configuration
  19. rbrown55
    rbrown55 New
    Peter
    Will this be ok for the ptfe spray? want to try that before tearing things down
  20. Peter Van Der Walt
    Yes! Perfect! They say its Teflon based
  21. rbrown55
    rbrown55 New
    Ok well I am about to spray it on and cross my fingers
  22. Peter Van Der Walt
    Crossing with you!
  23. rbrown55
    rbrown55 New
    This video was after about 5 passes back and forth after spraying it…what you think? Still sounds funny especially on the backend but it hasn’t locked up yet
    Should the screw be kind of wobbling up and down? Seems somewhat logical since it is so long and the point of contact with the x axis would be the stiffest point but I have no idea what I should be seeing
  24. Peter Van Der Walt
    Actually looks and sounds "good"!
    Have seen far worse! Your whipping is not excessive, squeeking noises are gone, looks relatively smooth (will get better over time - nutblocks take a couple runs to bed-in)
    Might have a bit of leadscew bend on the end there but I don't think its bad enough to warrant a new leadscrew.
    • That dust hose getting squashed in the back there might someday cause a bind-up , consider adding a Swing Arm
    • or it might cause EMI docs:blackbox-x32:faq-emi [OpenBuilds Documentation] (Not a shielded/earthed hose - will get quite charged with static electricity from the particles it sucks in rubbing on the inside - when it discharges to nearby frame/wiring it causes EMI symptoms) - earthing it should be something you consider doing
  25. rbrown55
    rbrown55 New
    Thanks Peter
    The vacuum hose actually does go over the top as I have a poor man swing arm if you will where I attached a small rope to a hook and run the hose through it. I had just been vacuuming the floor and disconnected the vacuum to empty it so I tossed the hose up on the table
  26. rbrown55
    rbrown55 New
    I do have one other symptom I will video and post separately on the z axis. Soon i hope. Have so many things going on at the moment
