HELLO SIR I HAVE INSTALLED CNC 1500 WHEN I CLICK ON CONNECT IT SHOWS PORT CLOSED I CHANGED PORT 3 TO OTHER PORT BUT IT SHOWS FILE NOT FIND PLEASE HELP ME
Which machine, from where did you purchase? (We don't have a "1500" at this time so trying to determine what you have, what machine, what controller, other missing details not provided in first message etc)
hello sir this error is showing when i click on connect [18:38:37] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device! [18:38:38] [ websocket ] Bidirectional Websocket Interface Started Succesfully [18:38:39] [ update ] Checking for Updates [18:38:44] [ connect ] PORT INFO: Port is now open: COM1 - Attempting to detect Controller... [18:38:44] [ connect ] Attempting to detect Controller (1): (Autoreset) [18:38:44] [ connect ] Attempting to detect Controller (2): (Ctrl+X) [18:38:45] [ connect ] Attempting to detect Controller (3): (others) [18:38:45] [ connect ] Attempting to detect Controller (4): (DTR Enable) [18:38:46] [ connect ] ERROR!: No Response from Controller - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for troubleshooting information. Closing port COM1 [18:38:46] [ disconnect ] PORT INFO: Port closed
please any one knows how to fix this issue i cannot connect my cnc with openbuild and i have no black box with this machine
LEAD? Workbee? 1515 is just the size? Which machine? From where (OpenBuilds or 3rd party?) Which controller do you have on it? Then what DO you have?
"OpenBuilds CONTROL" is our CNC host application for our machines that use our controllers: docs:blackbox-x32:start [OpenBuilds Documentation] For your machine, which is not running a compatible controller, use the software your vendor supplies. Contact them for assistance with their machine/controller thanks.
